**cylindrical plastic piece found in oil pan**
Old Nov 26, 2007 | 08:07 PM
RC_CADMAN's Avatar
after taking off my oil pan i found a plastic cylindrical piece with a metal sleeve-like object in the middle. any ideas of what it might be?
Old Nov 26, 2007 | 08:11 PM
Intense_Spence's Avatar
First make sure you didn't break anything off of your oil level sensor. If not that it could be off the oil pump shaft, but not likely I don't see how it could come off without other major problems.
buzz12586's Avatar
Could it be the oil pump coupler piece? The one that goes on the shaft?
Old Nov 26, 2007 | 08:24 PM
wrd1972's Avatar
Old Nov 26, 2007 | 08:55 PM
SS RRR's Avatar
That's what I'm thinking.
Old Nov 26, 2007 | 09:01 PM
speed_demon24's Avatar
Originally Posted by wrd1972
Old Nov 26, 2007 | 10:51 PM
urbaNHunter44's Avatar
Get a picture of it..
Old Dec 3, 2007 | 08:12 PM
86formula's Avatar
been there, done that, its the oil lvl sensor thats sticking out the side of your oil pan lol
Old Dec 3, 2007 | 10:51 PM
Mr. Wolf's Avatar
CPS crank position sensor???
Old Dec 4, 2007 | 09:50 AM
The Engineer's Avatar
LTs have a crank trigger (reluctor ring) behind the crank-shaft timing chain gear, but not a position sensor (4 triggers per crank revolution). The crank trigger sensor (pick-up) is in the bottom of the timing chain cover and could never get down in the oil pan. Also the pick-up is copper, not plastic.
WD
Old Dec 4, 2007 | 10:40 AM
Mr. Wolf's Avatar
sweet
Old Dec 4, 2007 | 04:25 PM
SS RRR's Avatar
WD
OBDII LTx engines have a CPS. OBDI cars do not.
Old Dec 4, 2007 | 06:10 PM
I don't believe they are "true" CPS's even though they may be called that, as they actually generate crank triggers (4 per revolution with the reluctor) as opposed to a true CPS with "one" position w/ magnet.
WD
Old Dec 4, 2007 | 06:44 PM
SS RRR's Avatar
WD
What I'm saying is there is no relucter gear for OBDI LT1 cars.
Old Dec 5, 2007 | 03:56 AM
blown383's Avatar
If its vanilla in color its the tip of the low oil level sensor.
-B
