**cylindrical plastic piece found in oil pan**
First make sure you didn't break anything off of your oil level sensor. If not that it could be off the oil pump shaft, but not likely I don't see how it could come off without other major problems.
LTs have a crank trigger (reluctor ring) behind the crank-shaft timing chain gear, but not a position sensor (4 triggers per crank revolution). The crank trigger sensor (pick-up) is in the bottom of the timing chain cover and could never get down in the oil pan. Also the pick-up is copper, not plastic.
WD
WD
WD
WD
What I'm saying is there is no relucter gear for OBDI LT1 cars.
