***header install*** - wont start!...any ideas?
Old Jun 5, 2005 | 11:17 PM
narlydude's Avatar
ok so i had a rough time getting my headers in prolly worse then anyone. but anyway everything finally made it on. i go to start it and it cranks over and back fires and shuts off. (striaght out the headers). i tried 3 more time and it would crank over again. any ideas? i dont have the 02 sensors in or the intake elbow, MAF or the CAI in. The drivers side erg out the header isnt in either. i thought it would start tho still.....hmmmm....what you guys think?
Old Jun 5, 2005 | 11:22 PM
CamaroSS30thAnn's Avatar
Re: ***header install*** - wont start!...any ideas?
install the 02s adn the intake and it will start
Old Jun 5, 2005 | 11:23 PM
ayalam's Avatar
I would put everything back on then try it. o2 shouldn't be the problem I ran my car open headers.
Old Jun 5, 2005 | 11:25 PM
blind527's Avatar
Sometimes the car will stumble and die w/o the o2 sensors plugged in.
I hooked up EVERYTHING before I started it...o2's are on, all EGR/AIR tubes are connected and clamped down.
Old Jun 6, 2005 | 12:37 AM
camarokid24's Avatar
Sounds to me like your plug wires are out of order. From what you described I have had that happen before to me with my bros truck.
Old Jun 6, 2005 | 12:42 AM
narlydude's Avatar
i checked the order but i will check again. i will get back to guess wednesday cuz i need to order a new elbow(1le) hopefully it starts
Old Jun 7, 2005 | 02:50 AM
white93lt1's Avatar
do the elbow for sure and def. check the wires i had the exact same probllem and looked again and it was the wires on wrong on the opti....changed it..bam fired right up
Old Jun 7, 2005 | 07:54 AM
Like My Taillights?'s Avatar
My car did the same thing with the elbow off, don't worry about it. Get it all back together again and I bet it fires up just fine!
Old Jun 7, 2005 | 08:21 AM
CreatiVe2's Avatar
my car wouldnt turn over AT ALL when i had the MAF disconnected...
Old Jun 7, 2005 | 09:12 AM
Jon97Z's Avatar
Exactly. Finish re-installing the intake/MAF. My car would turn over, but not fire without the MAF connected.
Old Jun 7, 2005 | 09:21 AM
1SlowFormula's Avatar
Actually if you unplug the MAF it will start, but it will be in a limp mode with limited power. It is designed this way to get the vehicle home in case the MAF goes out...
If you have it pluged in and not hooked up to the TB then your car does not see any airflow and it has trouble starting...
Just unplug the MAF and try to start it, this is the way I clean my TB, I just unhook the MAF and take the elbow off and it runs fine, and just doesn't have a good tune that way...
Old Jun 7, 2005 | 09:45 AM
Jon97Z's Avatar
He's got a '96 and I'm assuming he's got OBDII. It WON'T start without the MAF connected.
Old Jun 7, 2005 | 11:05 AM
narlydude's Avatar
thanks everyone! hopefully everythign is good today or tomorrow i will put it all back together. i keep you posted =)
Old Jun 7, 2005 | 11:10 AM
Good to know, I guess that is another benefit to the OBD-I's
Old Jun 7, 2005 | 11:12 AM
I just noticed your in Doylestown, your not too far from me, if you need any help give me a shout and I will try to help you out...
