$388.00 for cap rotor and distributor...
Old May 22, 2005 | 10:15 PM
  #16
hammersz28's Avatar
Re: $388.00 for cap rotor and distributor...
Hey man; Can I make a suggestion? Buy yourself a delteq system, it may be just a little more expensive, but you won't regret it. I replaced my opti from the chev dealership twice within 6 months of each other(ouch) . For some reason the optis just don't hold up as good as the original . Just a suggestion to save you some money in the long run.
Old May 22, 2005 | 10:24 PM
  #17
Hawk350's Avatar
i would love to but if my optical sensor is F**cked, then I would still endup replacing the opti..besides, I am selling my car at the end of the year... Looking to get a v10 monster for the spring
Old May 23, 2005 | 09:11 AM
  #18
Hawk350's Avatar
Just ordered mine from DAL.....COOL GUY!!!! $298.80 for the full unit Should have it in by the weekend. Hopefully
Old May 23, 2005 | 10:14 AM
  #19
Old May 23, 2005 | 03:50 PM
  #20
Hawk350's Avatar
Dal rocks!!! Opti will be in tomorrow
Old May 23, 2005 | 04:21 PM
  #21
MEAN LT1's Avatar
if it is a non-vented opti, how does moisture get removed?
It doesnt...
Old May 23, 2005 | 09:04 PM
  #22
heatz's Avatar
I changed my opti tonight. It took me three hours with not to much of a hassle. All I had to do extra was pull the tensioner for the vortech. I cracked mine open and looked inside to find lots of rust and oil. It was terrible. I should be up and running at full speed now.
One thing to remember is you need two water pump gaskets. Around here most of the places only stock one. So I had to go to two stores.
Good luck with the install
Old May 23, 2005 | 11:05 PM
  #23
Hawk350's Avatar
I began to remove mine tonight....so far I removed the air pump, disconnected the opti, driained the coolant....removed the bolts from the water pump (6 of them) How do I budge this thing? Do I tap it with a rubber mallet? It seems to be on there pretty tight. New opti from Dal will be in tomorrow. I am hoping to have all assembled by wednesday night
Old May 23, 2005 | 11:11 PM
  #24
Just rock and wiggle the water pump off the dowel pins. Some gentle persuasion with a big screwdriver might help.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
heus
Sep 8, 2015 12:01 PM
