$2500 to spend?? What to do?
Old Jan 29, 2004 | 02:58 AM
StreetRacingTA's Avatar
As you can see in my sig. that I already have full exhaust and intake. My question is what should I do for the most bang for the buck. I know nitrous will be a good start to some higher hp but how much can a stock block take if i were to get some heads and/or a cam with nitrous? I would rather spend the money the right way the first time so I dont have to double back in the future. Please list parts and prices. Thanks
Old Jan 29, 2004 | 04:29 AM
jkipp84's Avatar
Since there're so many different directions you could go with the money, I'd sit down and figure out exactly what you want to accomplish. Then get in touch with www.cmotorsports.com or the shop of your choice and get some guidance on a package that'll do what you're looking for.
Old Jan 29, 2004 | 05:15 AM
97SS0594's Avatar
i know exactly what to do!! make checks payable to the donny's super charger fund!! LOL. no, seriously though i would sit down and figure out were your gonna see your biigest gains
Old Jan 29, 2004 | 05:23 AM
Tair's Avatar
Agreed. The biggest thing I had to think of before I started spending $ was what my final goal was. You can be fast on the street, or fast at the track, or both. My goal is to be competitive on the street, in case someone revs me out, to have the car feel like it's going fast, and to run mid 13's all night long at the track. (stock = 14.7 @95mph) Come up with a REALISTIC goal. To me nitrous sounded cool at first, but the refill idea, and not having the power there ALL the time swayed me away from it.
Old Jan 29, 2004 | 07:43 AM
chesee48's Avatar
Defiently. Because like Tair said with nitrous, that the power isnt there all the time. Thats EXACTLY why i bought a forged 383 stroker. To handle n20, because frankly i dont want a power adder there 24/7 and put wear and tear on a stock bottom end (supercharger/blower, turbo)
But think about what you wanna do first.
Big qusetion to, emmisions or no?
Old Jan 29, 2004 | 07:53 AM
Dan Oldham's Avatar
LT4 Hot Cam setup: $505 out the door through www.gmpartsdirect.com. It includes 1.6 roller rockers, lt4 valvesprings, cam (obviously), retainers, etc.
LT4 Knock Module $40-$50
52mm throttlebody $350
3.73 Motive gears $220
Aluminum Driveshaft $250
Drag Radials $200-$300
Short shifter $150
PcmsForLess Tuning $200
Y-Pipe $150-$190
Vinyl Racing Stripes, HKS stickers, Aluminum commando wing- $1000
Old Jan 29, 2004 | 09:27 AM
Compstall's Avatar
Nice!
But then, if you're like me, $2,500 won't go very far at all. Outside of the roller rockers, I have YET to do anything major to the motor on my car and I've got over $6k into my car, most of my stuff was bought used, and NO it wasn't in stereo crap either.
Old Jan 29, 2004 | 09:34 AM
chesee48's Avatar
Short shifter $150
Y-Pipe $150-$190
I like the hot cam kit, lt4 KM, LS1 DS, DR's, tuning and shifter...
However, i'd rather also go with 4.10's and get a TA girdle w/ stud kit, LCA, Re-location brackets, PHR if lowered, SFC..
You can have all the power in the world, but if you cant hook then whats the sense?
Old Jan 29, 2004 | 10:10 AM
timmyZ28's Avatar
Short shifter $150
Y-Pipe $150-$190
Add a GMPP Heavy Duty Timing Chain (~$250) and you are set!
Old Jan 29, 2004 | 10:30 AM
93Z286Speed's Avatar
this man speaks the truth!
Old Jan 29, 2004 | 11:57 PM
ttt
Old Jan 30, 2004 | 12:15 AM
hot_red_z28's Avatar
AFR Heads and a custom grind cam with 1.6 rr's...
you won't be sorry...
Old Jan 30, 2004 | 12:26 AM
justahoe's Avatar
12 bolt, around 2500, my 7 1/2 in just died. 12 bolt on its way
Old Jan 30, 2004 | 05:23 AM
magius231's Avatar
depends on what you want to do...if you just want to be fast on the street I would do:
cam kit (call Cmotorsports) - with all the installation BS your looking at about $1200 total.
heads - get Lloyd to port your heads with the rest of your money
This should make plenty of power, sound pretty nasty and get you running mid-low 12's without traction (which you will not want to try to get)
if you want to be fast at the track,
12-bolt/9 inch - $2300
you won't see any power gains, but you can throw some big slicks on the car and run high 12's at the track with your current setup.
Old Jan 30, 2004 | 10:01 AM
Would I be able to install the cam kit myself to save a little cash or is it one of those things that you want to leave to a professional? Also wouldn't a good tune help pick up some extra horses?
