Z28 vs. SS/WS6 Sway bars
Old Dec 8, 2003 | 04:45 PM
XKnightRider's Avatar
On a 2002 Z28/TransAm vs. the SS/WS6
Is there a difference in the size of the swaybars?
If so what is the stock size of each?
I know that the upgrades are typically 32/21mm or 35/25mm front and rear respectively. Just want to know what I was starting with as I have an SS.
Thanks!
Old Dec 8, 2003 | 07:01 PM
CODY BEHNKE's Avatar
Stock Z28 & T/A = 30mm front
Stock SS & WS6 = 32mm front
SLP SS & Firehawk = 35mm front
I am pretty sure rears are all the same (21mm) unless it is 1LE
Old Dec 9, 2003 | 08:23 PM
chuck's Avatar
1993-2002 Z28/Formula/Trans Am - 30mm front / 19mm rear
1993 1LE Z28/Formula - 32mm front / 21mm rear
1994-1999 1LE Z28/Formula - 32mm front / 19mm rear
1996-2002 base Firehawk/WS6/SS - 32mm front / 19mm rear
2000-2002 Firehawk/SS with optional Bilstein or 1LE (01-02) option - 35mm front / 21mm rear
For most cars the 32mm GM front bar and stock 19mm rear are a good street setup. Another popupar combination is the solid 35mm ST (not hollow SLP) front bar and the 21mm GM rear bar.
Everyone I know that has tried the 25mm rear bar has reported a very tail happy car. I think that is too much rear bar. That is somewhat dependant on what springs you have. Generally speaking, stiffer springs prefer small bars, and softer springs prefer bigger bars.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
