Z06 Maf
Old Jun 29, 2006 | 12:19 PM
mook99TA's Avatar
Z06 Maf
Is there a difference between an LS1/LS6 MAF and a Z06 from the same years 99-02. My buddy has a 3000GT that they do a MAF swap on to a Z06 MAF but wasn't sure if there is a difference between the two.
Old Jun 29, 2006 | 12:25 PM
SSpdDmon's Avatar
Re: Z06 Maf
Yup...it's bigger in diameter 85mm vs 75mm....and the Z06 might be descreened from the factory (not 100% sure though).
Old Jun 29, 2006 | 03:05 PM
Greed4Speed's Avatar
Re: Z06 Maf
a "Z06" MAF would be an LS6 MAF since the LS6 is the engine of the Z06....
Old Jun 29, 2006 | 04:12 PM
mook99TA's Avatar
Re: Z06 Maf
isn't the ls6 the same MAF as the LS1
Old Jun 29, 2006 | 09:05 PM
Re: Z06 Maf
Look at this logically.
ZO6 MAF is larger than an LS1 MAF. That was covered.
Which engine comes in the Z06 (C5 since this MAF came in the C5 ZO6)?
That would be the LS6.
Old Jun 30, 2006 | 09:11 AM
mook99TA's Avatar
Re: Z06 Maf
I under stand that but I thought that LS1 and LS6 MAF's where the same size
Thanks I now know that the LS6 MAF is 85mm and the LS1 is 75mm
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
