Is a Z06 cam really worth it???
Old Oct 16, 2003 | 07:14 PM
  #16
ULTIMTEORANGESS's Avatar
hotcam will give you better low end for sure.i think peak #s are similar.
Old Oct 16, 2003 | 08:34 PM
  #17
mystic98Z's Avatar
Who makes the hotcam? Is it a GM part?
Old Oct 16, 2003 | 08:43 PM
  #18
yes,just check with whoever sells GM perf. parts.
Old Oct 16, 2003 | 08:46 PM
  #19
Knowklew's Avatar
www.gmpartsdirect.com
part # 12480033
Old Oct 17, 2003 | 03:01 PM
  #20
Lan01z's Avatar
I dont understand the description.
DESCRIPTION: Camshaft "Gen 3" Hot Cam
The "Gen 3" (RPO-LS6) engine is used in all 1997 and later Corvettes, and 1998 and later Camaro/Firebird vehicles. This camshaft is comparable to the LT4 hot camshaft but for your LS1 engine. This kit includes 16 LS6 valve springs P/N 12565117.
I dont think it is correct.
Old Oct 17, 2003 | 04:04 PM
  #21
2001SS#3013's Avatar
That sounds correct to me. I think that specs are the exact same as the LT4 Hotcam but this one is for the the LS1. That is the one I have and am extremely happy with it. I bought the cam and had it installed for 400. Not too bad at least I don't think so.
Old Oct 17, 2003 | 04:07 PM
  #22
Lan01z's Avatar
This is what I dont understand "The "Gen 3" (RPO-LS6) engine is used in all 1997 and later Corvettes, and 1998 and later Camaro/Firebird vehicles" This says that the 1998 and later camaros/firebirds have the RPO-LS6 engine. I'm confusing the LS6 part of that description.
Old Oct 17, 2003 | 04:08 PM
  #23
Knowklew's Avatar
why is the hotcam package so much cheaper on www.gmpartsdirect.com compared to everywhere else?
Old Oct 17, 2003 | 06:34 PM
  #24
KamaroL98's Avatar
The hot cam sounds like the way to go...
I did run another LS1 6 speed similiar to mine, only difference was he has the LS6 cam and i still outran him by like 2 car lengths, this was motor to motor. Id rather start with heads the then a cam, mabey beef up the pistons and vavles while your there...
Old Oct 17, 2003 | 06:36 PM
  #25
is the hotcam emissions legal?if you have inspection its something to consider.
Old Oct 17, 2003 | 08:02 PM
  #26
99BlackZ28T56's Avatar
My guess is because they charge $80 S&H
Old Oct 18, 2003 | 03:31 AM
  #27
My84Z's Avatar
on ls1tech.com in the eastern section a guy was selling a used but good shape one for 100 bucks. just passing it along.
Old Oct 18, 2003 | 07:42 PM
  #28
dist0rtion_69's Avatar
I had this cam for a while. Considering the work to put a cam in, I think I would have bought a used comp cams grind rather than the ls6. It really leaves some low and midrange power on the table. There are alot of cams that will idle stock, or close to stock but make much more useable power. (Ie. MTI Stealth Cam, Old Man Cam, TR220 with quiet exhaust). However, for the price the ls6 cam is a bargain if you can't afford more.. Most gain 2-3 tenths and similar mph. The hotcam will make more lower end, but has more bark than bite. Drivability is sacrificed when it really doesn't need to be. For some this won't be a problem, but just throwing in my opinion.. Good luck with whatever you do!!
Cheers,
Old Oct 18, 2003 | 09:19 PM
  #29
LPE_wannabe's Avatar
Cheers,
so in your opinion i shouldn't get a hot cam cause there are cams that untap more power and still not affect the everyday drivability??? like i said i would like a little lope cause i'm going with LM so it's already gonna be loud as **** but anyways...which one would you recomend in that sittuation out of all availiable??? thanks
Old Oct 19, 2003 | 12:17 AM
  #30
My84Z's Avatar
tr 224 or 220 i would go with the 224 but i think the lm with headers is just to much cam or not.
