yes another cam question
Old Apr 9, 2009 | 06:52 AM
  #16
AL SS590 M6's Avatar
Moderator
Originally Posted by Chrome383Z
It's not a concern. STOCK guides are hard as hell, they aren't going to wear. Now, if you go to an aftermarket head with bronze valve guides then you can start to see a problem (hence the recommendation to run HS rockers or equiv).
For a stock headed (or 243) motor, that article is BS.
Right on the money. I just got a chance to read the article and it was written by someone at Trick Flow.
They said that the big problem is with heads that have bronze guides. But if you look at the computer illistrations of how the rocker comes up on it's tip after about .550 an presses the valve down with just the tip edge after that it might get you to thinking.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
