wtf is wrong my my LCA's
Old Aug 15, 2003 | 05:48 PM
stik6shift00's Avatar
they are BMR LCA's w/ relocation brackets and ive had them on for about 4 months and i love them and have had no problems but as i was taking a turn this morning (relativly fast) i hear a loud POP noise and my rear end felt like it slide out a bit, i went staright home and tightend the 2 bolts on the relo's (3/4's on both sides if that helps) i only did this on the drivers side to see if it would help, it seems like i have a little wheel hope just starting off normal and my car shakes on tight turns (like trying to drive in a circle)
did i tighten the bolt too much?
Did i tighten the wrong bolts?
Old Aug 15, 2003 | 07:59 PM
thechef's Avatar
check you torque arm sounds like you snapped it
Old Aug 16, 2003 | 07:12 AM
AL SS590 M6's Avatar
Moderator
Are they greaseable? If so. Do it. Sounds like they are binding.
Old Aug 16, 2003 | 01:28 PM
teke184's Avatar
how bout transmission mounts?
if they are torqed down i don't see how the lca's would cause all that noise
Old Aug 16, 2003 | 11:11 PM
Drew778/94Z's Avatar
Do the BMR's have Polly bushing all around or did you get rubber one's?
I got the BRM polly rear and rubber front and found out later you don't grease the rubber one's it eats it away.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
