WS6 vs TA - differences?
Old Nov 1, 2003 | 05:35 PM
Desolate_Flux's Avatar
Just trying to figure out what makes the 2002 WS6 different from the Trans Am...? Appearance...? Under the hood...?
And is the 2002 WS6 35th Anniversary like the 2002 Camaro...?
Old Nov 1, 2003 | 05:49 PM
Z28CamaroGuy's Avatar
The WS6 has a "Ram Air" hood, and stiffer suspension.
What do you mean?
Old Nov 1, 2003 | 06:03 PM
I saw online that the 1994 Firebird is the 25th anniversary.
Doing the right math, that would mean that the 2004 (yep, I know, doesnt exist.) is the Firebird's 35th anniversary.
Am I correct? Or did GM skip two years just to make the 2002 the 35th anniversary?
Old Nov 1, 2003 | 06:07 PM
The WS6 package may also include a LS6 intake if im not mistaken? 2002 was both the Trans Am's and the Camaros 35th anniversary. The 35th Trans Am is yellow with black rims.
Old Nov 1, 2003 | 06:08 PM
chpmnsws6's Avatar
its not the 35th anniversary, its the collectors edition ws6.
the SS has the 35th anniversary and that what your thinking about probly
Old Nov 1, 2003 | 06:09 PM
1992 is the 25th anniversary for the Camaro, I don't know about the Trans Am.
Old Nov 1, 2003 | 07:50 PM
Ok, so what are the trims for the Firebird then?
Pontiac Firebird (V6)
Pontiac Firebird Formula (V8)
Pontiac Firebird Trans Am (V8)
Pontiac Firebird Trans Am WS6 (V8, equivalent to SS)
Pontiac Firebird Trans Am WS6 Firehawk (WS6+a SLP package)
Am I correct?
This seems so complicated to a feeble minded Camaro (V6, Z28, SS) owner.
Old Nov 1, 2003 | 08:51 PM
Old Nov 1, 2003 | 08:56 PM
RS Dragster's Avatar
Am I correct?
You're mostly correct.
The Firehawk can be a Trans Am OR Formula- differences of spoilers and front fascias. Other than than, some Formula's are V6's (at least older years, not sure about newest)
Old Nov 1, 2003 | 09:16 PM
Greed4Speed's Avatar
The WS6 is a TA w/a body kit and suspension package. It could be ordered w/the SLP kit too, just like the SS.
Think of a the Firehawk as a tuner option that could be had on the Formula or TA.
This is more or less how I view the differences.
Formula = Z28
TA = Z28, w/an appearance package
WS6 = SS but if you ask spyke more poewr fro the ram air and a magical suspensn that maed it rid smoothr, handel beter and ezer to lanch.
Old Nov 1, 2003 | 10:36 PM
Actually, apprearance wise WS6's and TA's are exactly the same except the hood, rims, and exhaust tips.
Here's a my TA w/ stock Gfx http://images.cardomain.com/member_i...734_8_full.jpg
Here's a WS6 w/ stock Gfx http://images.cardomain.com/member_i...66_18_full.jpg
Old Nov 2, 2003 | 01:40 AM
LetMeBurnU's Avatar
Formula = Z28
Old Nov 2, 2003 | 06:03 AM
chuck's Avatar
The differences between a 2002 WS6 and a base T/A are:
WS6 hood
WS6 airbox (sits higher for better airflow)
32mm 1LE front sway bar (compared to 30mm for the base)
17x9 wheels (compared to 16x8)
275/40/17 tires (compared to 245/50/16)
Muffler and tailpipes (flows a little better than the base)
That is it. From '96 to very early 2000, the WS6 cars had much of the 1LE suspesion (sans shocks). From '96-'01 the WS6 had the power steering cooler, which was optional on the base car and is standard on all 2002.
All 2001-2002 V8 F-bodies have the LS6 intake.
Performance wise, they are about equal.
The first year for the Trans Am was 1969. First year for the Camaro and Firebird was 1967. Do the math on the anniversaries; GM does not skip years to make an anniversary model.
Old Nov 2, 2003 | 01:08 PM
darrens99formul's Avatar
All Formulas are V8's.
Firebird= V6
Formula = firebird body + V8 engine
TA= appearance upgrade + V8
WS6 = firebird or TA body +v8 + ram air hood + suspension UG
Firehawk = one sweet friggin car
Old Nov 2, 2003 | 06:27 PM
False. Only the Camaro was made in '67. The Firebird/Trans Am didn't come out till '69.
Doing the math... the 35th Camaro was 2002, putting its first year at '67.
The Firebird didn't have a 35th, only a Collector's Edition that year. However, the 30th Anniversary was in '99, putting its first year at '69.
