Wrecked Z
Old Feb 16, 2008 | 10:45 PM
JFH's Avatar
JFH
Wrecked Z
I recently wrecked my 98 z and I tried to get it started the other day and it won't start. The fuel pump won't run it's like it won'ts to start so I took a spray bottle and gave it a shot of gas and still a no go!! Is there a safty switch or anything to keep it from starting?
Old Feb 16, 2008 | 11:38 PM
moroso99's Avatar
how bad did you wreck the car? its possible you messed something else up which would be stopping the pump from operating
Old Feb 16, 2008 | 11:47 PM
2000GTP's Avatar
There is no fuel pump kill switch or anything like that.
Old Feb 17, 2008 | 12:56 AM
mrmint69's Avatar
You could check to see if its getting power.
Old Feb 17, 2008 | 07:37 PM
JFH's Avatar
JFH
The car was on the roof when it stopped. The fuel pump was still running until we turned the switch off. When you try to crank the car it turns over good but the pump doesn't run and we tried spraying gas in it but it's like something has the fuel and the fire shut down.
Old Feb 17, 2008 | 09:27 PM
MasterEvilAce's Avatar
Did you just flip it over and try to start it? You're not supposed to ever do that, incase you did. Oil would basically cover everything, at that point. Sparkplugs are probably fouled, really.
Pump could have gotten burned out if it was continually running and wasn't submerged in the gas anymore...
Old Feb 18, 2008 | 07:03 PM
redlined4816's Avatar
Might have some kind of inertia switch that turns the fuel pump off it has been in an accident
Old Feb 19, 2008 | 11:06 AM
ss.slp.ls1's Avatar
If it won't start with fuel sprayed inside, then the pump is not your only problem.
speedracer1280
Sep 8, 2015 06:12 AM
sodak86
May 24, 2015 03:54 PM
1970judge
Cars Wanted
May 23, 2015 11:39 PM
mdenz3
May 22, 2015 09:25 AM
cmsmith
Apr 30, 2015 05:18 AM
