Window Motor Dying
Old Oct 23, 2002 | 02:21 PM
BardelSS's Avatar
Angry Window Motor Dying
My drivers side window is on its way out. Are there any articles on how to change it yourself.
Old Oct 23, 2002 | 02:56 PM
XKnightRider's Avatar
The instrucitons that come with it are decent. I have replaced 3-4 of them now on 3rd gens and 1 4th gen. It is no fun, a helper makes things go faster.
Old Oct 23, 2002 | 05:37 PM
Big Red Jim's Avatar
[SARCASM] A power window motor going out on an F-body? NO WAY! [/SARCASM]
They're not the most difficult things in the world to do....start by pulling the doorskin off, and the plastic sheet that's behind it. Once you get to that point, small hands are a help because you don't have much room to work with. You will probably need a hand when you're finishing the job, someone to hold the window up while you put stuff back together.
Old Oct 23, 2002 | 05:58 PM
dkeers's Avatar
Try a search for "basket" or "mbaskett". Its something like that, I don't remember for sure. He has a good write up w/ pictures on how to change it. Use duct tape to hold the window up while you pull the motor out. I did it in my 95 and it was't too hard.
Old Oct 23, 2002 | 06:38 PM
WillieD's Avatar
Check this site out:
http://home.swbell.net/shoebox/windowmotor.html
The install is pretty easy. Took me about an hour to change the one in my wife's camaro.
Old Oct 24, 2002 | 12:23 PM
MARSTAUT's Avatar
I have a good tip for you that will save alot of time and anger, after you get the inside of the door panel off, drill holes through the fiberglass where the heads of the screws are so you can get to them much easier.
Old Oct 24, 2002 | 02:17 PM
1967AND2002's Avatar
How long do I have?
When (time and/or mileage) did you motor die? I would like to get an idea of how much time I have left.
Keenan
Jan 19, 2023 12:24 PM
silvermansteve
Mar 4, 2015 05:02 PM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
