WILL I BREAK MY REAREND IF I RUN DRAG RADAILS???
I'm considering drag radails when I buy tires next (soon), are people having problems with them like breaking rearends, clutches etc, on bolt on modded motors? Thanks for your help.
99 SS, Dark Metallic Blue, M6
SLP lid, KN, TBB, SLP Y-pipe, loudmouth
ported MAFs
ported MAFs
With a bolt-on motor? Probably not.
Daily-driven 383 M6
"Real men drive opposite lock."
Daily-driven 383 M6
<font face="Verdana, Arial" size="2">Originally posted by Btchslp:
</font>
</font>
not a prob. will not break rearend not enough power.
It depends how abusive you are, but I have been running them for years with mild bolt ons, and never broke a rear axle on them. I did shatter the posi in my old '97 Z28, but that was spraying out of the hole on Mickey Thompsons. On the run before that I cut a 1.77 60'.
98 Z28 1LE M6 | Autox/RR toy
01 Trans Am M6 | Daily driver, some mods
1LE.net
1LE.net
I broke mine on drag radials, no problem. Shattered them. It is traction that does it. If your 60' times are over 2.0 you have less to worry about then if you are cutting low 1.8's. Plus the manual is harder on the rear than an automatic.
'94 Black Z28, 383, 700R4
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
I would imagine 3.5k to be pretty close to "safe."
-Evan Bangs
1998 Trans Am - 5.7L V8, A4, 3.23s, Lid, MAC Mid-length Headers and Off-road pipe, SLP Loudmouth, Tinted Windows, Yellow Painted Calipers, Chameleon Blue-Green paint.
Pics of my cars, friends, etc.
-Evan Bangs
Thanks for the input, I feel better about getting them now. Since I only have bolt ons I should be ok for the most part.
ported MAFs
ported MAFs
Based on the mods I see on your sig my answer is NO.
But I have heard of a few unlucky individuals break theirs at REAL sticky tracks such as at HRP. But most of these guys were either with built motors or every bolt on possible.
Rick
[This message has been edited by PhatT/A (edited June 26, 2002).]
Rick
Based on your mods you probably wont break your rear.I have close to 40 passes on my 4.10's with headers w/ORY,lid w/holley filter,MAF ends and BFG drag radials.I put down 342/355 to the wheels.Ive seen cars with less hp and softer launches break rears and axles!
Ive seen cars break rears on every kind of tire and mods.Its a risk you take. I launch anywhere from 3600-4000 dumping th clutch with 14 lbs of air cold.I cut mid to low 1.7 short times all day long.No problems except for alittle gear whine.
Its up to you though.Everytime you run you can break stuff.With drag radials and practice I dropped several tenths.Also I have a girdle and it is speculation if they work or not.IMO if its going to blow its going to.
I hope I helped out.
2001 Camaro SS M6
11.901@115.82 1.71 60 ft.
342 hp 355 ft/lbs
Boltons running on DR's
1990 Eclipse GSX M5 stock for now
2001 Camaro SS M6
342 hp 355 ft/lbs
Speeds8erM-1
Jul 18, 2002 11:36 PM
I ran a 2.2 and I was soooo happy hehe.
