widest 17"
Old Aug 5, 2003 | 09:17 PM
drasgear's Avatar
widest 17"
I know this has been beat to death, but before you flame me..... I did a search and spent about 2 hours going through the results without gettting my question completely answered. I will be getting 17" rims and want the widest possible on all four corners without rubbing. I saw plenty of posts for 17X11's, but I don't really want to massage the fenderwells and lips. Anyway, the car is the stock height, so I plan on going a bit taller to get rid of the 4X4 look as well as keep a taller sidewall for better traction. Has anyone run a 10" or 10.5" rim out back without clearance problems? I am probably just going to go with 9.5's up front as I know they'll fit and that is wide enough. Also, what backspacing in to keep it just inside the fenderlip? How about tire size? Thanks
Old Aug 6, 2003 | 10:24 AM
RedDevil's Avatar
I have sportlines on my car with 17x11 on the back with 315/35/17's, I don't have any clearance issues, I just can't ride with a moped in the back
Old Aug 6, 2003 | 10:41 AM
dis3as3d's Avatar
Did you have to trim the bump stops to make them fit? Did you have to "influence" the wheel tub with a BFH?
Old Aug 6, 2003 | 10:44 AM
RedDevil's Avatar
nothing needed for them to fix,didn't have to roll the fender, for thesse tires, I did for a 28x11.5x15 ET street thou
z28man86
Wheels and Tires
May 9, 2005 12:14 PM
frmula1
Wheels and Tires
12
Mar 17, 2005 04:48 PM
RocketCutlass
Wheels and Tires
Nov 22, 2004 11:01 PM
1KillerV6
Classic Engine Tech
Nov 18, 2004 10:48 PM
tweaked96z28
V6 Tech
Jul 1, 2003 05:08 PM
