Why won't my car go straight?
Old Jul 3, 2003 | 10:52 AM
  #16
Jay-mak's Avatar
Originally posted by amood
And when in rainy conditions, if you're flooring the car and it tends to "yaw" to the right that's not because the power goes to the right wheel first or moreso........it's the physics of the rotational force being applied in a certain direction. If the engine and tranny were built to rotate in the oposite direction, the car would yaw to the left. Again, you can see evidence of this in funny cars when they launch and have good traction the whole front end of the car will lift off the ground slightly and you can actually see the frame twisting at the front half of the car...this is the same force at work on an exaggerated scale. It's also why left turns are more "fun" than right turns.
Finally!!! Someone who knows a little about physics and momentum...you are exactly right.
good call!!
Old Jul 3, 2003 | 03:53 PM
  #17
Jaegermeister2k's Avatar
The car doesn't yaw to the right though,it slides to the right.The car will make a complete turn if i don't release the throttle and countersteer.
Old Jul 3, 2003 | 04:10 PM
  #18
SSCamaro99_3's Avatar
Amood, good call, I was behind on my thinking; but the point is that these cars will not stay straight in the rain.
Yaw is the technical term for rotation with respect to its vector of forward momentum. I think that's how I want to express that. Ryan Newman uses the term yaw to descibe a loose race car.
Old Jul 3, 2003 | 04:18 PM
  #19
I just though of yaw like in an airplane,when you yaw to the side,it's usually done slowly,the car's rotation on the other hand becomes faster the more you're at the gas.
Old Jul 3, 2003 | 04:38 PM
  #20
That's because the rotational forces of the driveline will increase as their rotational speed increases. F=mv if I remeber correctly where F=force (ie kinetic energy), m =mass, and v=velocity.
Old Jul 3, 2003 | 04:51 PM
  #21
Yeah i think. HEHE.Anyway,fact is my friends car has something i don't,and i want it.The posi differential that eaton makes should fix the problem.I gotta talk to people who use it i guess.
CARiD
Dec 26, 2014 04:20 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
