who has kumho tires? are they good tires?
Originally posted by zo6vette
are the Yokohama AVS ES 100's a quiet riding tire?
just curious what u guys set your tire pressure at? i set mine at 35 psi, would less tire pressure like 30 psi cause a tire to ride quieter?
Originally posted by Lan01z
The noise is really from the tread pattern and rubber compound of the tire. Letting the air out down to 30 psi sounds like a definitely no no to me. I'd say just get better tires that aren't noisy!
you shouldnt be running high pressure to begin with. I never run more than 32 psi.
35-36 sound way too high IMO.
If I go racing at the track, on street tires, I never do a burn out but I do reduce air pressure to 28psi. then up them back to 32 before I go home.
Originally posted by SpecForceZ28
My door stickers says inflate tires at 30psi cold. 36psi if exceeding 100mph, which I rarely do.
