Whining noise?
Old Oct 11, 2006 | 02:26 PM
MeanZ687's Avatar
Whining noise?
When i start my car for the first couple mins or so i hear kinda of a humming whinning sound and then is completely goes away and its only when i first start the car up. Does anyone know what this could be? give me some feed back thanks.
Old Oct 11, 2006 | 02:35 PM
2001NBMZ28's Avatar
Re: Whining noise?
Sounds like it could just be the air pump cycling - is it coming from under the drivers side headlight area?
Old Oct 11, 2006 | 09:31 PM
MeanZ687's Avatar
Re: Whining noise?
Yeah it comes from the driver's side
Old Oct 11, 2006 | 09:49 PM
2001NBMZ28's Avatar
Re: Whining noise?
I still have AIR and it's not really that noticeable. Sometimes the pump goes bad and it's really loud. You can pull the AIR PUMP fuse under the hood while it's making the noise to be sure and see if the noise immediately stops...if it does it's probably the AIR pump. In colder weather at night with the lights on it'll also dim the headlights/dashlights when it cycles.
Old Oct 11, 2006 | 11:34 PM
V6toZ28's Avatar
Re: Whining noise?
Whining noises normaly come from the passenger side ... and if she gets to loud I make get out and walk ...
Old Oct 12, 2006 | 09:31 PM
mmmchickenboy's Avatar
Re: Whining noise?
as stated above, definitely the air pump's electric motor running.
autoxr166
Sep 25, 2015 04:21 PM
cristian1311
Sep 12, 2015 08:16 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
Jul 7, 2015 07:19 PM
