wheres the pcv valve located on the LS1 engine?
Old Jul 20, 2002 | 04:07 PM
zo6vette's Avatar
Post wheres the pcv valve located on the LS1 engine?
just wondering wheres the pcv valve located on the LS1 engine
Old Jul 20, 2002 | 06:08 PM
nikkev's Avatar
Exclamation
As you are facing the engine,it is on the left hand side about mid-way down the valve-cover.It's buried under a ton of crap on my '98,not sure how it is on newer models.Good luck.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics
Old Jul 21, 2002 | 07:56 PM
phil1001's Avatar
Post
on my 2000, it was on the left side, about 3 or 4 inches from the throttle body, you'll see a hose that is 1/2" or so and it connects two hoses together, hard to spot, because you wont see it until you disconnect the hose.
2000 black WS6 6speed
318 RWHP 322 RWTQ stock
best et: 12.72 with the et streets. 60' 1.81
bestmph: 109.72 first time out, no mods, on the street tires
Mods: centerforce dual friction clutch, moser 12 bolt w/4.10's
BFG dragradials, PRO 5.0 shifter
whats next: put the borla on, take baffles out of WS6 hood, tb bypass, et streets
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
