What's Wrong With My Horn?
Old Aug 18, 2002 | 01:30 PM
VetteThreat's Avatar
Red face What's Wrong With My Horn?
My horn has been sounding really weak lately. When I lock my car using the keyless entry system it emits a very short, staccato like sound instead of the deep long beep it used to have. When pressing the horn the same thing happens. I took it to the dealer, they repaired it under warranty, but the problem still persists. Any suggestions?
Black 2001 Z28 Auto
Mods: Borla full cat exhaust, SLP ram air, SLP 160 Thermostat, SLP smooth bellows, MTI lid
Best 1/4: 13.469 @ 105
Old Aug 18, 2002 | 02:50 PM
JDHarris's Avatar
Post
You probably got water in the horn... you can either take it off and try to dry it out which MIGHT fix the problem, or you can replace the horn unit. You probably ran through a puddle and splashed water up there. It's facing towards the front of the car on the passengers side below the battery. Hope this helps.
Old Aug 18, 2002 | 11:42 PM
jgkinsofla's Avatar
Post
I'm taking my car in to the dealer tomorrow - WISH ME LUCK! HAHA. That's one of the things I'm getting checked though. Come to find out there's actually 2 horns, emitting 2 different tones - a low "A" note and a higher "F" note - something like that. I'm missing the lower note for sure - my horn sounds like a rice burner.
'99 Z28 A4 BLACK
▪ SLP air lid, K&N filter, air box mod, Borla exhaust, HPP3, 160* stat, Magnecor 8.5 mm wires, NGK TR55 plugs
▪ Pioneer DEH-P77DH, Polk speakers
Old Aug 19, 2002 | 09:36 AM
ZZed's Avatar
Post
The same thing happenned to me. It was either water or overuseage. They replace the entire horn assembly because I blew out the low tone. No problems since.
2000 Camaro Z28 Monterey Maroon Metallic, auto,leather, 323 posi, Monsoon w/CD, T-tops, K&N
Old Aug 19, 2002 | 11:03 AM
goaliedave40's Avatar
Thumbs up
I was wondering why my car started sounding like a Fiat. Good info.
1999 Z-28 M6: Gran.MAF, LS1 MoSports intake, K+N filter,Corsa exhaust, PowerSlot rotors, Hoch. strut tower bar, still working
Old Aug 19, 2002 | 01:09 PM
NEWBIE T/A's Avatar
Lightbulb
Yeah, both my '99 T/A & SS had that problem.
I was beginning to think it was restricted to just that year - apparently not.
By any chance do you wash your underhood ?
I try to be careful , but it is possible I wetted 'em.
Oh, well.
Later !
Britt
'99 T/A
Best 13.071 @ 104.92
Now own '99 SS # 2073 !
12.969 @ 105.44
Old Aug 19, 2002 | 03:47 PM
ZZed's Avatar
Post
I think a big puddle could do it. I also have a quick trigger with that horn. You need it in Chicago.
Old Aug 19, 2002 | 05:52 PM
Pony Punisher II's Avatar
Post
My 99TA does that too! and so does my GF's 99 Firebird. She has had hers "fixed" by the dealer 4-5 times. It works for about 1 week, then goes bad again. This just keeps happening. I wonder what is causing the problems were having. Something had to be majorly wrong somewhere... ie crappy design which GM is too cheap to recall.
99' Trans Am Ram Air, NBM, LS1/A4
84' Trans Am Anniversary Edition
Old Aug 20, 2002 | 12:02 AM
jgkinsofla's Avatar
Post
Well, it is in a pretty sucky location - probably gets wet everytime you drive in the rain! Don't even have to go through a big puddle. I never had a problem with my '96 - horn situated higher then?
'99 Z28 A4 BLACK
Old Aug 20, 2002 | 12:05 AM
jgkinsofla's Avatar
Post
IT'S PROBABLY THE HOLES that appeared on the '98 and newer models! That's it - water just runs right up in there when you wash it, or drive in the rain. Ok now, what's the fix? Relocate it?
'99 Z28 A4 BLACK
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
