What's up w/the LQ4's low RPM horsepower peak?
Old Mar 15, 2004 | 11:43 PM
AdioSS's Avatar
West South Central Moderator
http://www.gm.com/automotive/gmpower...ehicle/lq4.htm
GM lists the LQ4's peak outputs at 300hp@4400 / 360tq@4000 in the lower level vehicles (3/4 and 1 tons), but in the higher end model such as the Denali, they add another 15-25hp peaking at 5000rpm.
Is this just marketing trying to make the higher end (more expensive) models look better or are there actual differences between the motors?
http://www.gm.com/automotive/gmpower...ehicle/lq9.htm
The LQ9 is rated at 345hp@5200 / 380tq@4000
What is changed to get the extra power there? I notice the compression ratio is at 10.0:1 instead of the LQ4's 9.4:1. I've been told that these motors got the LS6 head. Is that true?
Has anybody actually dyno'd these motors to find out the actual power?
The reason I ask if because I'm considering the purchase of a Chevy Express with the LQ4.
Old Mar 19, 2004 | 01:56 AM
AdioSS's Avatar
no replies?
Old Mar 19, 2004 | 03:20 AM
RS Dragster's Avatar
Sorry man, can't exactly help you. Don't know anything about LQ4's.
Now, if it was an LS1 I'd be all over your question
Old Mar 19, 2004 | 04:42 PM
mullettour's Avatar
As far as I can tell the only difference between the LQ4 and the LQ9 is the pistons. The LQ4 has a dished piston and has a CR of 9.4 whereas the LQ9 has a flat top piston giving it a CR of 10.0. Both heads are supposedly the same heads as the LS6 except for a larger combustion chamber of 71.06cc.
Oh yeah, even among the LQ4 hp varies 25 and tq varies 10 among different models.
timmy39120
May 8, 2015 11:41 AM
Noenav
Apr 30, 2015 01:06 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
