whats a ta cover???
Old Dec 6, 2002 | 10:51 PM
stik6shift98's Avatar
whats a ta cover???
i think its something to help your rear end.....
is it worth it and what exactly does it do????
thanks
Old Dec 7, 2002 | 01:01 AM
LS1_03's Avatar
pumpkin cover for your rear. i dunno how, but supposedly it holds the rear end in a lil better. and gives you a drain plug if i remember correctly. also looks better.
Old Dec 7, 2002 | 06:35 AM
2001NBMZ28's Avatar
It puts pressure on the bearing caps on hard launches, looks great too. You can also get an optional stud kit with it.
www.taperformance.com/gm.htm
Old Dec 7, 2002 | 07:45 AM
psychocabbage's Avatar
I believe summit sells the same thing without the "TA" name for less.
Think of it as a girdle. It just adds support.
Old Dec 7, 2002 | 08:46 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
It is a deeper aluminum cover, that applies pressure to the carrier bearings, so they dont "float" upon hard acceleration. As said above, it also has a drain plug for convenience.
SteveC
Old Dec 8, 2002 | 12:09 AM
is it worth it?????
Old Dec 8, 2002 | 06:12 AM
redz_02's Avatar
for 150 bucks, you get an unrusted cover, suposedly designed to disipate heat, stronger, and has the fill and drian plugs. When i put in my 4.10's i am going to throw on a G2 rear end girdle. Same thing just different company. I think it is worth it.
Old Dec 8, 2002 | 10:55 AM
supersp0rt's Avatar
i have one sitting at home waiting to go on. you cant have too much protection.
Old Dec 8, 2002 | 01:18 PM
hows the install on it.....hard???easy????
Old Dec 8, 2002 | 02:06 PM
2001NBMZ28's Avatar
Easy. www.installuniversity.com has a great guide.
Old Dec 8, 2002 | 04:30 PM
i see thats gonna be very useful.....
Henson071
Sep 18, 2015 04:01 PM
Wart Hog
Sep 8, 2015 05:53 AM
Bails098
Aug 17, 2015 05:15 PM
CARiD
Jul 7, 2015 08:19 AM
SergheiS
Jul 5, 2015 03:27 AM
