What exactly is the weak spot in the LS1 bottom end?
Old Jul 12, 2008 | 07:05 AM
  #16
AL SS590 M6's Avatar
Moderator
Originally Posted by Sparkz28ss
yes you can...just not much
You can NOT bore a 97-98 LS1 block at all. There's only .005 extra there for a clean up hone for new pistons.
Old Jul 12, 2008 | 01:35 PM
  #17
Sparkz28ss's Avatar
like i said...not much
Old Jul 13, 2008 | 08:05 AM
  #18
Moderator
Boring is using a cutting tool to shave a larger amount out of the bore leaving around .005 for the hone.
Then it's honed the last .005 to get proper piston fit.
If you only have .005 from the factory you can't use a boring tool at all. With .005 you can only hone.
Victor Lamb
Aug 26, 2017 02:52 PM
Gtpguy
Jan 26, 2015 04:50 PM
Killer94z
Jan 13, 2015 12:06 PM
