valve springs
Old Jun 9, 2004 | 07:50 PM
NZ12'S's Avatar
valve springs
quick question: can the valve springs be changed without pulling the engine?
Old Jun 9, 2004 | 07:59 PM
Z28Venom's Avatar
There's no need to pull the engine or the heads to change valve springs nowadays..
Just get you a good spring compressor tool, and have at it..
Check out the More Performance tool at thunder or the the Da Vinci tool.. It does two at a time..
Old Jun 10, 2004 | 03:26 AM
AL SS590 M6's Avatar
Moderator
And the air fitting to go into the sparkplug hole. Hook it to an air source and the valves can't open while your changing springs.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
