Vacuum Leak - part numer request
Old Jul 30, 2007 | 11:52 PM
ssintheuk's Avatar
I have a 2000 Camaro SS in the UK (US Spec). We have discovered that a hissing noise was coming from the pipe that I have circled below - I think it maybe causing my engine management light to come on.
I have plugged the hole, however I want to replace the part - can anyone give me an idea of the part or part number?
The image is not my car - I notive the image I have borrowed the guy has some air recirculation pipe work missing - is this a performance enhancment does anyone know?
Old Aug 1, 2007 | 04:04 AM
AL SS590 M6's Avatar
Moderator
The part that you have circled is the hook up for the PCV valve.
Old Aug 1, 2007 | 02:24 PM
ssintheuk's Avatar
Thanks Bud, for letting me know what the pipe was!
Does anyone have an idea of what the part number maybe?
Will this pipe leaking affect my performance?
I have taped it up for now - it sounds better (no hissing noise on tick over)!
Old Aug 1, 2007 | 03:03 PM
Marc 85Z28's Avatar
GM part number for the PCV tube/hose assembly is 12590632. I get parts at 10% above wholesale - my price on that was $69. Expect a counter sale to be near $85-$95. You might pay a good bit more based upon your location.
And leak in the PCV system will absolutely turn on the SERVICE ENGINE SOON light. The vacuum leak causes a lean condition, and will set DTCs P0171 and P0174. Not only will it cause the SES light to illuminate, but depending upon the severity it will affect driveability.
Edit: www.gmpartsdirect.com is a good source for GM parts that can be expensive or hard to find. But be warned, they charge excessively for "shipping/handling". Regardless, even with the high fees, they are usually cheaper than any alternative. I do not know if they ship overseas.
Old Aug 5, 2007 | 11:15 PM
blacknight's Avatar
If it's just the hose that goes from the pcv valve boot to the intake then just go get some 5/8 vacuum hose at any autoparts store. Costs about a whopping $2.00.
Old Aug 6, 2007 | 01:44 AM
lvgoldie's Avatar
I had to replace mine also - it takes 11/32 Fuel and Oil Resistant Tubing Double Wall Non-Reinforced hose. I bought the whole (GM/dealer only) part #12590632.
I only changed the PCV valve & the hose circled in your picture. I have kept the remaining assembly incase something else goes....
CARiD
Jan 27, 2015 06:27 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Hurin
Dec 13, 2014 07:38 PM
