Using Cable From OBDI W/OBDII Conector On a OBDII Car?. (Messed Up Gauages)
Old Jun 9, 2008 | 09:38 PM
ENRKyle20's Avatar
I have a 95 camaro that is OBDI with OBDII adapter. I figured it was just a standard OBDII adapter. SO I was going to use digimoto program on his car to check some stuff one, he has a 04 GTO... Now when he pluged it in it turned out I didnt have drivers for the USB adapter.. so I unpluged it and took it in the house to try to find the driver. then said when we was on his way home there was electrical problems (tach not working, fuel gauage problem).. he never had these problems before.
this cable just says OBDII on the back, is it not just a standard OBDII connector?..
it is posable that it was made wrong.. could 2 of the pins be connected or something cause this?..
Old Jun 9, 2008 | 10:07 PM
ENRKyle20's Avatar
I just learned that it will not work, because it uses diffrent pins..
but I still dont know if pluging this in causes the problems hes having.
Old Jun 9, 2008 | 10:30 PM
Marc 85Z28's Avatar
My sisters 03 Cavalier exhibited those EXACT same symptoms after the local emissions station performed the semi-annual emission test. Both the tachometer and the fuel gauge stopped working, but everything else seemed OK. PCM checked OK with no stored DTCs. I disconnected the battery for a few minutes, reconnected, and everything worked fine. No problems since.
Old Jun 9, 2008 | 10:48 PM
ENRKyle20's Avatar
hmm. well. thats good news. I just talked to him on the phone and he said everything seem normal now. thats quite odd, but atleast nothing is toat!
thanks
Sarahrope64
Nov 27, 2014 11:17 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
Jul 4, 2005 05:00 PM
