Underdrive pully
Re: Underdrive pully
Gears will still be more effective...even in the 10-bolt. However, I've had my ASP pulley on for 4 years with no problems and it was probably worth the 8-10rwhp advertised.
most gains....gears
easier to install....pulley
you probably won't feel the gains from the pulley, you'll definaately fell the gains from the gears, but you'll also need to get it programed to change the shift points or speedo...so the cost is alot more
Good input fellow, my ASP pulley is on the way, it will complet the job.
Arnoli
Originally Posted by SpeedDemon02SS
Even though i am using the stock carrier? Should i just wait till i can afford a 12 bolt?
if you can its a good investment.i wish i had done this instead of fixing my 10 bolt over and over.
only thing that happens is when everything is on.AC,rear def. ect and im stopped the needle will go into the red zone but once im moving it goes back into the normal range.
unless you have a custom system you shouldnt have any stereo problems.you could always have your idle raised.i had mine raised slightly.
Originally Posted by GoFast908Z
cuz i do have a good sized stereo, and an Optima Yellow Top. I had the idle speed raised for my stall convertor, but don't want it too high.
