Two Things I really need answered
Old Aug 13, 2002 | 11:37 PM
Boo Yeah's Avatar
Post Two Things I really need answered
I have a 98 SS, Loudmouth, lid, SLP MAF, Filter, Short throw,
I am going to do Hooker headers and y-pipe, should I put an electric cutout after the y-pipe? Where do I get an electric cut out (website wise)?
I am thinking about using a fidanza flywheel and need to know if it will have any problems. I really need to know about anyones experience with fidanza flywheels.
And one more thing can this car take the abuse of a 100shot wet kit???
Old Aug 14, 2002 | 12:03 AM
rockls1's Avatar
Thumbs up
Put the cutout right befor the I-pipe goes over the axle. As far as te wet kit, as long as it's set up correctly, you should have no problems. Make sure a qualified person intalls the Nitrous, just to be sure.
Old Aug 14, 2002 | 12:33 AM
racechick's Avatar
Post
In my experience, wet kits are a lot less reliable and more complicated to work with when tuning. A 125 dry shot would be your bet bet. It goes right to the throttle body. It is also safer b/c a dry kit with WOT (Wide open throttle) will shot the nos only when you need it. It takes away the need for computer control. As far as the cut out goes, the reason you cant find any is b/c there are so many good exhaust systems available that they are not needed. The sound that comes out of them is annoying to say the least. The best investment I have made for exhaust flow is the random tech Y-pipe. Which I ordered online.
Hope this helps
Old Aug 14, 2002 | 04:24 AM
PhantomTA's Avatar
Moderator
Post
Actually..
A dry kit is the setup typicaly installed BEFORE to MAF.
And the wet kit is installed at the TB.
A wet kit simply sprays both n20 and Fuel, thus eliminating the need for computer, or raised Fuel pressure control.
hope THIS helps
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
[This message has been edited by PhantomTA (edited August 14, 2002).]
Old Aug 14, 2002 | 01:13 PM
V6toZ28's Avatar
Post
First off guy, here's a link to a manufacturer of an electric cut out. Since you have a loudmouth, if there is room put the cutout between the Y-pipe and the resonater.
And for racechick ... cutout's happen to be the most common and proven best bang for the buck mod you can do on an exhaust system. Other than open headers, a cutout will flow more and provide more performance than any other exhaust mod.
As for an A/M Y-pipe. Unless you get it sans cats, it really will not do you much good. Besides the guy's getting hooker L/Ts and already has a loudmouth ... the cutout should be good for 4-5 more ponies in this set up.
As far as the N20 ... wet or dry you should be able to handle 100 shot fine. Work with someone who has some experience and make sure your A/F R is a little rich. A MAFT might be a good investment along with Scanmaster.
Good Luck
'01 Mystic Teal Z28
A4/3.73
Mods List Here
12.12/112.81/1.70 60'
325 rwhp/341 rwtq
www.MysticZ28.com
NorCal LS1/LT1
"To play it safe is not to play"
Old Aug 14, 2002 | 09:20 PM
Boo Yeah's Avatar
Post
I will use a wet kit because i have a dyno and it does nto matter as well as i will be getting the ls1 edit program at the same time so i will be able to control and get it right. I really need to know about the fidanza flyweel as well as how much the electric cut outs weigh and also wether or not the 6.0 l truck block will bolt up to my tranny
KYWes
Apr 15, 2015 07:11 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
sscott
Jan 17, 2015 04:30 PM
heavenly_six
Dec 10, 2014 12:23 AM
Hal Fisher
Sep 14, 2002 09:36 PM
