Twin Turbo Help
Old Dec 11, 2002 | 05:59 PM
jcnorthwest's Avatar
Twin Turbo Help
My buddy is having trouble finding less than 9 to 1 pistons so he can turbo his lS-1. Here is what I was wondering. I don't have anyone around that can answer my question. I have been told the LS-1 truck 6 liter motor has the same intake and exhaust runners as a LS-6 head. If this is true can you put the 6 liter head on a 2000 Vette LS-1 block and put a LS-6 intake on it? Secondly if you do that what is the compression ratio? Is there any hi-performance info out there on the LS-1?
Thanks in advance for any help you can offer.
Jeff
Old Jun 4, 2003 | 05:29 PM
ABeasst's Avatar
you can put a LS6 intake on any ls1...I put one on my 99....dont know the answer to your compression question though.
Old Jun 4, 2003 | 05:34 PM
RS Dragster's Avatar
Yes, putting 6.0L heads on any LS1 block will lower the compression. Not sure how much, but I believe it's like .2-.3, someone please correct me if I'm wrong...
Old Jun 4, 2003 | 08:32 PM
crazyswede1027's Avatar
you may want to call a piston manufacturer. They should be able to anwser all of your questions any maybe even make you custom pistons for your applications. I think hte current high performance pontiac has an article on a piston manufacturer who makes custom pistons. Other than that I am no help to you.
Old Jun 8, 2003 | 06:19 PM
RxNupe's Avatar
There's an article on GenIII cylinder heads in GM High-Tech Perf (May 2003 issue). I'm sure this would answer all your head questions. In fact they recommend LQ4 or LQ9 6.0L truck heads for blown and turbo applications. The article gives you all the stats. Unfortunately I don't know what that crap means so i can't answer your exact questions.
http://www.gmhightechperformance.com/
Old Jun 8, 2003 | 08:09 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
you are the second person i've head that from
are 6.0 heads different than5.3 and 4.8 heads?
i thought a 5.3 was a destroked 6.0 and a stroked 4.8
Old Jun 9, 2003 | 01:10 AM
slvrbird2000's Avatar
Trey, the 6.0L heads are basically Poorman's LS6 heads.
If you want to really have a good LS1 for boost, either call Thunder for some forged pistons that will lower your CR, or get a 6.0L Longblock (aluminum heads, cast # 317). Or you could do a search on www.LS1Tech.com
scott
Old Jun 9, 2003 | 05:43 AM
treyZ28's Avatar
scott
whats different about them
me thinks my truck needs a head swap and cam (at 10k miles )
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
