Turn signal lights
Old Oct 2, 2003 | 10:39 AM
SP99SS's Avatar
Turn signal lights
Anybody ever change out a front turn signal bulb?
One of mine went out last night and I haven't looked at it yet to see how easy/difficult it is to change.
Can I change just the bulb or do I need to replace the whole unit?
Thanks,
SP
Old Oct 2, 2003 | 11:53 AM
Jilly's Avatar
Just change the bulb. It's really not hard but it's easier if you have skinny arms.
Old Oct 2, 2003 | 05:28 PM
camaro322hp's Avatar
Re: Turn signal lights
Thanks,
SP
pretty easy. you'll see a "door" under the car directly under the lights. remove the bolts holding the "door" closed and swing it open and you're at the back of the housing. the "door" is actually more like a plastic flap. you'll know what i mean when you get under the car.
Old Oct 2, 2003 | 05:46 PM
99blackSS's Avatar
Just the bulb, its pretty simple, very hard to do from the top.
Old Oct 2, 2003 | 10:19 PM
Stumper66's Avatar
Don't listen to them. It's easy to get to from the top, tough from the bottom.
Just get a 10mm socket, undo the one bolt that holds in the headlight, slide it out and you have easy access.
Old Oct 2, 2003 | 11:48 PM
mPoRtSsUcK's Avatar
Exactly what I was going to say. Pop the headlight out and you've got easier access than you could ever have going from the bottom.
Edit: Whoa, gotta change that sig. GOt rid of that car over a year ago!
Old Oct 3, 2003 | 01:05 AM
hmmm... wasn't that tough from the bottom. unless you consider about 60 seconds tough...
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
formula79
26
Aug 5, 2002 12:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
