Tune up Price Opinion
Old May 2, 2012 | 02:28 PM
taviz's Avatar
I just talked to a buddy of mine who used to work at a Chevy dealership now has his own place.Sat.,were gonna tune up my 2000 Z-28 and for an even $250.00 for gm approved plugs, wires, and a fuel filter,and he's gonna clean out the mass air flow sensor also. Good deal??
Old May 2, 2012 | 05:53 PM
rod442's Avatar
Re: Tune up Price Opinion
whats his labor rate, and how much time did he quote? might be fair, parts alone are probably close to a hundred. guessing $20 filter, 25 plugs, 40 wires. close?
Old May 7, 2012 | 07:39 AM
rv93's Avatar
not a bad deal. a set of original plugs from autozone is $85. and swapping them is a huge pain.
Old May 7, 2012 | 09:47 AM
rod442's Avatar
rv93... oe plugs - 85 from autozone? I would hope no one would ever buy those. ngk's are only about 3$ each. or did you mean plugs and wires?
Old May 7, 2012 | 01:30 PM
Marc 85Z28's Avatar
That is roughly 2.5hrs labor, and close to $100 in parts if using regular plugs. That's a good deal. I recommend GM wires and copper resistor AC Delco plugs (or NGK). Gap them to .040" If he quoted you the iridium plugs for that price, it's an even better deal!
The same services at a GM dealer would likely run a little over $350.
rod442 - rv93 is probably talking about the updated plugs GM recommends for these engines, which are iridium AC Delco plugs, and are somewhat expensive.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
grabbem88
Feb 22, 2015 11:16 AM
Jazsun
Dec 29, 2014 12:14 PM
