tps code - please help!
Old Mar 8, 2008 | 04:36 PM
Z28luvr's Avatar
Replaced plugs last night, cleaned tb, maf, and descreened maf. Now I have a tps code. P0224 iirc. Can descreening the maf cause a tps issue? Or is it just coincidence that the tps code came up now? Thank you in advance.
Old Mar 8, 2008 | 10:41 PM
ss.slp.ls1's Avatar
Sounds like something happened to it when you took off the TB and cleaned it. Did you clean the sensors, or just the inside of the TB?
Old Mar 9, 2008 | 08:49 AM
Z28luvr's Avatar
I cleaned the maf, but not the tps (I didn't know you could clean the tps). BTW, the code was P0122 (tps low voltage). The last time I had that code, it was caused by a faulty map sensor. I took it to my local auto parts store and had the code erased. If it comes back, I will do a little more investigating.
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
STAYBG
Jul 15, 2002 02:21 PM
