tire size
Originally posted by camaronewbiess
and the 2000 ss came with the same rims i assume??
Any bigger then 275 on the SS rims doesn't look quite right and has no benefit other then the tires costing more. The biggest I have seen on a SS rim is 315s.
I have 245-50-ZR16 on my stock wheels on my '98Z28 and to me they look kinda small. I also am wanting to go with something wider and bigger but I am not sure what size tire the stock wheels can mount. Eventually I am going to purchase 17x9.5 American Racing S202 Megnetallic 2-piece painted wheels. I liked the wheels that are mounted on the Intimidator SS and think it would look really sharp on my '98 Z28. Could someone tell me what size and width tire I sould go with on stock rims? Thanks.
StealthZ28 if you go with a 17 inch rim and the stock size for a SS tire 275x40x17. It will be the same overall diameter as the 245x50x16. But they will have about a 1 inch wider footprint. In other words in my opinion unless you autoX there is no real advantage other then wheel style change switching to a 17 inch rim
So 275-40-17 tires will fit my stock rims? I will eventually purchase 17x9.5 rims in the future. I am going for style. Plans for performace mods are happening right now. A GMMG cat-back is being installed right now, SLP lid, SLP headers by this Fall. And my Xenon ground effects are going to be re-painted this Spring. But like I said, my stock tires and rims just look kinda small. And I want to get wider 17" tires with the rims I mentioned before. Thanks.
