Throttle body bypass question.
Old Dec 1, 2003 | 08:40 PM
99blackSS's Avatar
I did the TB bypass and one of the caps (that you put on where the hoses used to run) was very loose and now my radiator is low on coolant. Is there still some coolant that goes through the throttle body after doing the TB bypass?
Old Dec 1, 2003 | 09:01 PM
teke184's Avatar
nope
are you sure you connected both hoses together from each side of the tb?
and that all the clamps are tight?
Old Dec 1, 2003 | 09:34 PM
99blackSS's Avatar
Yeah, but I had to clamp on the loose cap and it caused a tear in the cap. My waterpump was making a squeaking noise, but I think that was just because the radiator was so low.
Old Dec 1, 2003 | 10:18 PM
Dark Angel's Avatar
Originally posted by teke184
nope
Like he said. No. The only way coolant gets through the TB are the 2 hoses that should now be connected together. The caps that are put on the TB are just to stop debris and stuff getting into the ports on the TB incase you reconnect it.
I did the TB bypass and don't even have caps on the TB ports.
Potent77
Mar 16, 2022 12:13 AM
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
RedLineRev
Jan 23, 2003 03:51 PM
