Are these plugs bad?
Old Jan 1, 2007 | 10:30 PM
scof0elife's Avatar
I was getting backfire after header install. I did a number of things to try and correct it. Change o2 sensors, got a basic tune and still ended up getting popping sounds. So I thought I would check my plugs. I ended up changing the plugs on the passenger side because I really dont know what a bad plug looks like. A friend of mine took a look at #1 and #3 and said they were good. So if I'm getting popping sounds from the exhaust then I'll need to check #5 and #7, I didn't get a chance to check those. But below are pictures of the plugs I removed from the passenger side. The pictures might not help but let me know what you think anyways.
Old Jan 1, 2007 | 10:37 PM
LUDA0840's Avatar
whats kind of plugs? and what did you gap them to?
Old Jan 1, 2007 | 10:38 PM
LUDA0840's Avatar
i had the same thing happen to me and I just swapped my plugs and it went away...
Old Jan 1, 2007 | 10:39 PM
scof0elife's Avatar
They're the tr55's and they were gapped at .50 like what everyone else is running.
Old Jan 1, 2007 | 10:44 PM
scof0elife's Avatar
I hope it goes away then
Old Jan 2, 2007 | 03:39 PM
2000GTP's Avatar
Although the pictures aren't the best, the plugs appear to be in good shape without any buildups on them. Have you also checked your plug wires and are you sure you don't have any exhaust leaks?
Old Jan 2, 2007 | 06:22 PM
scof0elife's Avatar
I might have an exhaust leak but I didn't know it would cause backfire?
Old Jan 3, 2007 | 02:58 PM
AL SS590 M6's Avatar
Moderator
yep
Old Jan 3, 2007 | 02:59 PM
scof0elife's Avatar
Well I forgot to mention that when I took off a couple of my wires, they looked a little burned. Do you think that may be the case?
Old Jan 3, 2007 | 03:13 PM
2000GTP's Avatar
If they are burned through enough where they are grounding out to metal, then this could cause your problems as well.
jocamino
May 14, 2015 07:37 AM
eanhl2004
Apr 4, 2015 12:01 PM
captcorvette
Mar 7, 2015 12:37 PM
grabbem88
Feb 13, 2015 03:09 PM
Amshnock
14
Jan 18, 2015 11:47 AM
