Texas Speed & Performance LS2 402 cid Short-Block Special!
Old Sep 12, 2005 | 04:35 PM
Trevor98ramair's Avatar
Components:
Your Choice Of Pistons:
Diamond -2cc Piston
or
Diamond -15cc Piston
or
Mahle -12cc Coated Piston
Rods:
Scat's New 6.125" LS1 Specific 900hp Rods w/ ARP Bolts
Crankshaft:
Eagle 4340 4" Stroke LS1 Crankshaft
Bearings:
Clevite LS1 H Main & Rod Bearings
New GM Cam Bearings
* This kit also includes the LS2 components needed to install it into a LS1 vehicle such as:
Front Cover
Timing Set
Cam Sensor
Rear Cover
Valley cover
This Complete Short Block Pacakge Is On Special For $3800 Complete with NO EXCHANGE OR CORE CHARGE!
If a customer is wanting to use their existing LS2 engine block they can deduct $700 from the price, and you can deduct another $175 if you do not need the LS2 timing chain, valley cover, timing cover, or rear cover.
Below are the compression ratios using each piston listed above with factory LS2/LS6 cylinder heads and AFR 225cc cylinder heads. For these numbers, I am assuming a .051" thickness cylinder head gasket and that the piston is coming .007" out of the cylinder.
Diamond -2cc Pistons: 11.97:1 with LS6 heads, 10.91:1 with 225cc heads
Diamond -15cc Pistons: 10.35:1 with LS6 heads, 9.57:1 with 225cc heads
Mahle -12cc Pistons: 10.68:1 with LS6 heads, 9.85:1 with 225cc heads
We have been building quite a few, and we offer them as short-blocks and complete long-blocks. We can set it up as bare or as complete as you prefer. Feel free to e-mail me at trevor@texas-speed.com with any questions or concerns. I will be more than happy to put a complete estimate together to e-mail to you so you know exactly what everything is going to cost shipped to your door.
Trevor
F'n1996Z28SS
Aug 23, 2023 11:19 PM
importkiller94
Jan 17, 2015 09:03 PM
Chris 96 WS6
33
Sep 3, 2002 09:48 PM
Chris 96 WS6
Jun 27, 2002 05:03 PM
