Temp guage problem...
Old Jun 10, 2005 | 08:46 AM
02BlackSS's Avatar
I have a 02 SS and the temp. guage stays right at 210 degrees when warm. I'm not sure but I think that the car comes stock with a 180 degree thermostat and if that is the case eithier the guage is off by 30 degrees or I have something else wrong. Is anyone else haveing this problem? Any input on this would be great. Thanks...
Old Jun 10, 2005 | 09:00 AM
SSpdDmon's Avatar
Re: Temp guage problem...
It's ok. 99-02 f-bodies have a "dummy" temp guage. Unless the engine coolant temp is pretty low or really high, it will stick around the 210* mark. Stock t-stat is 195 I believe. But, even with the 160* I had in my '99, the guage still read 200~205. If you want to see real ECT, you'll need a scanner of some sort (Autotap, HPTuners, Predator, etc.).
Old Jun 10, 2005 | 09:02 AM
02BlackSS's Avatar
Ok, Thanks. That had me a little worried.
Old Jun 10, 2005 | 09:17 AM
teke184's Avatar
yeah...another one of GMs brilliant ideas to satisfy the masses...
to many people complained about a fluxuating guage...so they made it read the same temp from about 100-240degrees
and i think the LS1 stat is 180 due to the alum block...the LT1 was 195.
i've been throwing around getting a guage pod and installing a REAL temp guage.
Old Jun 10, 2005 | 09:23 AM
Knowklew's Avatar
I have also been considering a water temp gauge and oil pressure gauge, since i dont trust GM' opiate for the masses technique
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
