t-top only?
Old Dec 23, 2003 | 12:36 AM
andreyZ's Avatar
Question t-top only?
Hi all. I started thinking about buying a 2000+ z28, but I am in doubt, did GM make a regular coupe (not t-top)?
Old Dec 23, 2003 | 12:44 AM
Z28Venom's Avatar
Yep.. They did...
I saw my cars twin or almost twin the other day. It was a 2000 Z28 with Hardtop...
Old Dec 23, 2003 | 01:14 AM
99blackSS's Avatar
50-60% of the fourth generation Camaros have t-tops. Why don't you want t-tops?
Old Dec 23, 2003 | 05:28 AM
chpmnsws6's Avatar
they leak
Old Dec 23, 2003 | 06:57 AM
Mighty's Avatar
The only time my T-tops have ever leaked was when I was at a car wash and aimed the nozzle directly at the joint between the window and the T-top. It has been through driving rain and not so much as a drop got in then.
Old Dec 23, 2003 | 07:13 AM
95GRNZ's Avatar
Originally posted by red91tsiawd
they leak
My 00 Z28 has 51K miles and no leaks whatsoever. Not even when driven through a car wash.
Then again, I don't have piston slap or rattling panels, either.
The tops on my 95 leaked a little bit if driven through car wash, but in normal driving there were no problems whatsoever. Nothing which would've affected on daily operation. After all, it just water, you know.
Always makes me smile when hear/read people complaining about leaking t-tops...
TS
Old Dec 23, 2003 | 07:20 AM
z28chrizz's Avatar
In a good rainstorm (you know those summer tropicalish downpours) my T's will provide my left leg with a drop or two of water every 5 minutes or so. Never did that until I autocrossed my car w/o SFC's... im thinkin i stretched my car
Old Dec 23, 2003 | 08:14 AM
IXLR894Z28's Avatar
106,000 miles, never leaked.
Old Dec 23, 2003 | 08:55 AM
99blackSS's Avatar
Here is my honest attempt at being unbiased on the t-top debate.
Pros:
-cool/fun
-compliments
Cons:
-insurance (according to my GEICO agent t-tops cost more to insure then the vert version of the same car)
-possible leaks
-some people have said they squeak
-body flex
IMO The cool/fun out weighs the cons, the leaks can be fixed, and unless you autocross body flex won't be a issue. A lot of people claiming they squeak say it was on a car they previously owned, which leads me to believe this was mainly on the older f-bodies. T-tops have come a ways since the 80s, the 80s f-bodies I have seen don't even have a place to put the t-tops when you take them out.
Old Dec 23, 2003 | 11:13 AM
Rice Eater 316's Avatar
I think a lot of that has to do with the Gen 3 camaro having problems with t tops leaking. My first car was an 85 Camaro w/ t-tops. Leaked like a **** Had to seal them shut with RTV.
I've owned 2 4th Gen Z28's (97 A4 and my current baby 02 M6) Both of them were hardtops. I would have gotten the t tops if I could but I wasn't going to turn down the car cause they didn't have em.
Old Dec 23, 2003 | 11:44 AM
lastZ's Avatar
well i tell ya what you will regret not getting a Z with T tops....nothing finer than taking the tees out in the summer and cruisin, and as far as leaking....nope, no problems in mine whatsoever...my boss has a 2000 SS not a drop of water in his car either. just my .02 cents
Old Dec 23, 2003 | 11:52 AM
kiztope's Avatar
No leaks on the 99.... They are awesome to have on those beautiful spring days....
Old Dec 23, 2003 | 01:04 PM
andreyZ's Avatar
because I live in Seattle
Old Dec 23, 2003 | 01:21 PM
95TA8280's Avatar
Both my 'birds (95 TA and 01 Formula) leaked, and both were covered under the warantee.....
Old Dec 23, 2003 | 02:16 PM
chpmnsws6's Avatar
arguement ended.....
yes i would be looking for a hardtopif i were u! my next f-body will be a hardtop
