System too lean
Old Dec 17, 2002 | 02:12 PM
ForestSwin's Avatar
System too lean
'System too lean' both banks (P171 & P174) no other codes.
Anyone had similar condition or knowledge about a cause. I am looking for advice- seems to be alot of good info on this website - I don't have a mechanic I trust yet and would like to know some possible causes before I take it to anyone . The SES light has come on a few times over the past few months – seems to go out and stay out after gas fill-up – however gas mileage has definitely decreased recently.
Old Dec 17, 2002 | 10:09 PM
stik6shift98's Avatar
i dunno what those codes are but id probably post it in advanced tech.......
Old Dec 18, 2002 | 11:23 PM
BoscoZ28's Avatar
I had the same problem. Basically, as you stated, you car is running lean, could be a number of things. 1st I would look for a vacuum leak. Other things to look at are the o2 sensors and have you changed the fuel filter latley? My car, turned out the fuel pump was going out. Do you have access to A-tap, to see how lean it is?
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 15, 2015 10:43 AM
camaro98_speed
Apr 22, 2015 11:26 AM
TechCam97
Sep 12, 2002 07:20 PM
