Synthetic oils
Old Jan 28, 2003 | 10:31 PM
  #16
stik6shift98's Avatar
u should be fine
Old Jan 28, 2003 | 10:52 PM
  #17
warner's Avatar
The reason I change my oil at 2k even with synthetic is it just makes me feel better. Sometimes that car gets driven extremely hard and I like to know it's fresh and clean. At high rpm you should want the best oil you can get. Also I've read even though synthetic doesn't break down it still gets dirty and going 6-7k between changes you should at least change the filter. You don't have to worry about going from one to the other as that is an old myth according to everything I've read. All the synthetics I've seen claim to be compatible with dino oil. Main thing is to keep it clean. With the car I had with 140,000 on it the oil would still look clean at 7-800 miles with hardly any carbon. It just doesn't hurt and only takes 15 minutes start to finish to do. You won't see too many race cars running dino oil. If you drive easy almost all the time I wouldn't be concerned.
Old Jan 29, 2003 | 03:03 AM
  #18
dmnall's Avatar
Originally posted by warner
Synthetics will also not "coke" inside your engine like dino oil will. Coking is that hard coffee looking stuff you see under your valve covers and I don't want any of that crap in my engine at 5000+ rpm.
Well actually what cause the Oil to Burn in the Valve Cover like that is the fact that scheduled maintanence was not addressed. Also cause can be of Valve Seals needs to be replaced and/or needs valve job or new valves. I have seen what happens to an engine when it is not properly maintained and oil and filter was not changed regularly, i.e. my neighbor gave me a Chevy 350 4 Bolt Main engine, I pulled it apart, and Valve Covers were caked with burnt Oil, Heads were caked as well. Rod Bearings had worn down both 5 and 7 on the Crank. So all in all the Block is good but Crank, pistons and heads were bad. I am going to be getting the block bored .030 over and build a 383 Stroker out of it. But when I asked about the oil changes and regular maintanence, the guy that gave me the engine said this " Well the Engine Leaked Oil so all I did was just add a quart every 3 days, but since I put in oil so much, why change it ? " So it really comes down to regular maintanence, this will keep an engine from going bad..
As for cleaning the engine, you can always do what the farmers have done, put in a quart of ATF and run the engine for about 10 - 15 minuets and then change the oil..
Old Jan 29, 2003 | 04:02 AM
  #19
96ssz28#395's Avatar
I use nothing but Amsoil.Since the day i got it new. How many companys can say they can go up to 12k on an oil change with there oil and filters. tells me they believe in there product. I personaly never let mine go that long but good to see if i had to i could.and be within there product guidelines. Check them out at. www.amsoil.com Take Care. Mike...
Old Jan 29, 2003 | 07:02 AM
  #20
bsmith's Avatar
Originally posted by psychocabbage
I will go until the light comes on. That should be about 7500 miles later.
I forgot to reset my change oil light once, and it wound up coming on shortly after I changed it for the second time. (just over 6k after resetting it last). I drive my car very easily, I would be interested to know what mileage yours actually comes on at. Considering how many dyno runs you post about, your car obviously is driven harder than mine.
I waited until 3500 miles to change Mobil 1 once, and everytime I drove it, I was watching the gauges. I guess the oil companies sucessfully brainwashed me into their recomended intervals. I like the peace of mind of using the highest quality things I can get for my car. So regardless of what anyone else says, I will continue to change my synthetics at 3000 mile intervals.
Old Jan 29, 2003 | 09:28 AM
  #21
Sax1031's Avatar
I have never worried about if an oil is "good" for xxx amount of miles. My concern has to do with particles floating around in oil. That is why I change my oil in my car every 3000 miles, I use synthetic but still change it. If you motor has to much particles floating around it will hurt the engine. I think the claim of 12k miles on same oil and filter, is about the same as the claim by k&n of 15hp change with their air filter.
Old Jan 29, 2003 | 12:19 PM
  #22
psychocabbage's Avatar
yeah i dont drive it like a banshee.. but at times I make my girl scared.. I do some stupid crazy things at times.. But I have the power to do it so why not when its actually safer...
I often race people that are already coming up on me at 90+ so we run in the 100's for a while.. Gotta love Texas highways! woo hoo! anyways... I drive hard but dont abuse... If it were a race motor, I would have it torn down every weekend (my family used to have a trailered drag car we ran on weekends and its motor would be rebuilt every weekend for the next) But since this is an everyday street car with no mods, why bother?
I too am using AMSOIL oil filters and all.. Just cause its easier to get than others..
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
