Sway Bars or Subframe Connectors
Hi from Germany,
i´m just starting to modify my ´99 Z28 and like to achive a better handling.
I´ll get a strut tower brace first and start to think about what to do next.
I´ve got enough money to either get new sway bars or the subframe connectors.
(By the way, both would be from Hotchkis - as they are the only ones i´can get here in germany - anybody got experience with these ?).
What should i do first Sway or Subframe ???
I would with the subframes, as you already have sway bars. One word of advise though, I would get the weld in ones. I've only heard bad things about the bolt ins, as they don't hold up to much.
I have Subframe connectors, and they did help - though my car has no swaybars...its a long story
Milo
Milo
I would suggest lower control arms as well and a panhard rod.
I wouldnt worry much about the strut tower brace.
I would (and did on my 1995) do it last.
Psycho Cabbage
2002 Camaro Z28
(6 sp) Bone stock
Webmaster for RaceHer.com
Check out the current polls and vote!
by the prìcking of my thumb, something wicked this way comes
-Traded in- 1995 Camaro Z28 (A4 (#6 I might add!),ES tranny mount and torque arm bushing,SLP CAI,ASP 34% Underdrive,Strange 3.73's (shredded Auburn),1LE alum driveshaft & intake elbow,Yokohamas AVS Intermediates,160-stat,MAF screen removed, HPP+(for shift points only),Borla Y-pipe, Flowmaster Force-II catback, Gutted Cat, Airlift Airbag, !TB Bypass, J&M LCA's, Bosch Platinums, Moroso BlueMax Wires, Free RamAir, Meziere Electric H2O pump, MAC 3point STB, BMR Panhard, SCR SFC's
Just installed:Nu-tek Heads (mild port) and Comp Cams 1.6RR's! New track and dyno #'s to follow!
best 13.44 @103.26
0-60ft 1.96
270 RWHP/296 RWTQ
0-60MPH 4.8sec
1987 Porsche 944S (waiting on LT1 mod)
Psycho Cabbage
2002 Camaro Z28
(6 sp) Bone stock
best 13.44 @103.26
0-60ft 1.96
270 RWHP/296 RWTQ
0-60MPH 4.8sec
Subs all the way! The camaro is a uni body car and should have these from the factory. It's the spawn of 90% of squeeks and tweaks. And yes get the weld in. The bolt in's will eventually wallow out the holes and render them near useless. A small notice in feeling but you will feel it.
autoxr166
09-25-2015 04:21 PM
