Supercharger, or Heads/Cam...
Old Sep 5, 2002 | 10:18 AM
  #31
Capn Pete's Avatar
Wink
Or get the 8.1L, 496 cubic inch engine that's going into the new trucks!! It's a big-block that's fashioned after the LS1 (ie: individual coil-packs per cylinder, and it's a full-roller motor too I believe)!!
When all else fails, go big or go home!
Seriously, build a good motor first, then worry about what separate power booster (supercharger/turbo/NOS) you want to add. If you build a motor right, you could have a fast naturally aspirated car --- then add your S/C, and the car will f'ing fly!!!
Old Sep 5, 2002 | 01:00 PM
  #32
Freak's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by supersp0rt:
cam...800
</font>
an 800 dollar cam? You must be shopping in the wrong place. 450 is the most expensive Ive seen. remember if he gets heads, he wont need springs and retainers, they will come with the heads...
I would go with the supercharger first. mainly because I would want to lower compression with an SC, and I would rather do that after I have the SC instead of doing it N/A. also as was said a blower specific cam will work great will a blower, but only OK with H/C so I would rather have the blower on when sticking that in...
More than one person has put an SC on a stock head/cam/block car, so they seem to be able to take it, even then the problem isnt going to be the heads or cam failing, it will be the pistions/rods/crank probably in that order
Old Sep 5, 2002 | 09:25 PM
  #33
supersp0rt's Avatar
Post
freak...i posted 800 as part of a package at TR with retainers and valve springs and the works...not just the cam, i should have clarified.
Old Sep 5, 2002 | 10:02 PM
  #34
Freak's Avatar
Thumbs up
ah HA!!! I read ya loud and clear.
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
rideordie
Sep 7, 2015 08:22 AM
