Summit Universal X-pipe and Flowtechs
Old Nov 18, 2004 | 01:04 PM
UltraZLS1's Avatar
I remember a guy posting how they fit his jet-hot headers perfectly on his LT1 and didnt even have to bend it.
So...does the 2.5 inch summit universal x-pipe system work just as good on long-tubes on an LS1?
And...do they fit flowtech headers? The jet-hots looked to have the same 3 bolt flange as my flowtechs.
thanks
Old Nov 18, 2004 | 01:36 PM
UltraZLS1's Avatar
Re: Summit Universal X-pipe and Flowtechs
Ok...would this bolt up to my headers? that is my main concern.
Here is the list...
SUM-630550 Exhaust Hanger, Use In Conjunction with U-Shaped Muffler Clamp, Steel Strap W/rubber Isolator, Each $5.95 $11.90
SUM-642125 Summit Universal X-Pipe Kits $89.95 $89.95
SUM-G4754ID Collector Reducers, Slip-Fit, 3.0 in.Coll.3-Bolt Flange, 3.0 To 2.5 in.ID., Pr. $19.95 $19.95
WLK-24236 Dynomax Race Magnum Bullet Mufflers $47.69 $95.38
Also...I cant find any turdowns to fit 2 1/2 inch. Which Will be how big the end of the muffler will be.
thanks
Old Nov 18, 2004 | 01:54 PM
teke184's Avatar
you will have to do some custom work. the collector on the driver side header for the LS1 angles out, not straight back like the lt1.
just buy a 2.5" U bent pipe...cut the legs off and you have 2 turndowns
Old Nov 18, 2004 | 03:47 PM
UltraZLS1's Avatar
So the collector reducer should bolt up to my flowtechs?
Old Nov 19, 2004 | 03:52 AM
AL SS590 M6's Avatar
Moderator
Collector flanges are pretty universal. I just went to the parts house and bought two 3" to 2.5" collector reducers and they fit my Dynatechs just fine.
generaldave
Sep 25, 2015 06:48 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
Pwilson59
Sep 3, 2015 08:47 PM
Slayer
Aug 17, 2015 03:55 PM
Jul 17, 2015 02:47 PM
