subframes
Old Oct 28, 2003 | 03:15 AM
GoFast908Z's Avatar
Member
subframes
what is the difference between the BMR weld in subframes and the SLP double diamond style weld in subframes.
I'll be running true duals, and I want lots of options for jacking points (you can jack the car up at any place on the weld in subframes right???) but I don't want them to get in the way of the duals.
Are the double diamond really that much different in performance and feeling? Enough to justify the higher price??
Old Oct 28, 2003 | 07:19 AM
teke184's Avatar
for extreme autoX or something like that you could probably benefit from the DD.
but for normal use, no way.
and as far as i know true duals prevent you from using the DD.
my bmr rock...plenty of install pics on my webpage in my sig..page 3 i think
Old Oct 28, 2003 | 12:43 PM
GoFast908Z's Avatar
Member
how much did it cost to have them welded up? It looked pretty difficult on your page.
Old Oct 28, 2003 | 01:33 PM
teke184's Avatar
it's really not that hard for a decent welder.
i got a REALLY good hook-up so i only paid $50 for mine. and it took a while since we had to remove the LCA's and scrape/wirebrush away the undercoating.
if you do all the prep work yourself it shouldn't be more than $100 or so.
just call around, i've heard stories of shops wanting $300!!!
i also was able to do some work on it myself while on the lift, like wirebrush and grind the welds, and then paint them.
just call around for pricing.
Old Oct 28, 2003 | 02:44 PM
GoFast908Z's Avatar
Member
does anyone know of some good places to have this done in the bay area? that don't cost too much?
Old Oct 28, 2003 | 11:13 PM
DARK AGE 53's Avatar
The SLP bolt-on SFC's are a excellent choice.
Al
Old Oct 29, 2003 | 02:40 AM
GoFast908Z's Avatar
Member
what is the price for the slp bolt ons vs the slp weld ons?
Old Oct 29, 2003 | 07:09 AM
teke184's Avatar
bolt ons are alot more.
probably the cost of a set of bmr's and most of the install cost...
there are disadvantages to the bolt ins as well.
some guys talk of the bolt holes lengthening with age, causing movement in the connectors and no longer providing the support. that is why a car developes squeaks and rattles, flex of joints over time, where the weld ins WONT move.
just call around some muffler shops, tell them what you need done and see what they say.
Old Oct 29, 2003 | 07:11 AM
SLP's web-site shows the bolt-on's cost $299.95 and the weld-on's at $199.95, the bolt-on's are powder coated and the weld-on's are just bare metal. You can get the SLP SFC cheaper by going to www.stealthperf.com . Here's a link on the install of the SLP bolt-on, http://users3.ev1.net/~cnl1/firehawk/subframe/index.htm
Old Oct 29, 2003 | 09:50 AM
GoFast908Z's Avatar
Member
those are the double diamond style, and i cant get those. More money, and I'll be running true duals.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Sep 18, 2015 04:01 PM
realistyc
Jul 28, 2015 07:32 PM
ducttape1975
Jul 10, 2015 06:29 PM
