stroker benefits?
Old Jun 20, 2005 | 02:10 PM
NLman3's Avatar
stroker benefits?
what kind of benefits would i gain from transforming to a 383? possible hp gains with my current mods?
Old Jun 20, 2005 | 04:29 PM
Kraest's Avatar
Retired
Re: stroker benefits?
Increased internals strength, increased horsepower, increased torque.
That cam is very small for a stock 346, let alone a stroker motor.
Mike
Old Jun 20, 2005 | 04:58 PM
myslowcamaro's Avatar
Mike
what would be the minimal size cam you would go with for a stroker? i was considering going with a 383 or 402 down the road.
Old Jun 20, 2005 | 05:24 PM
danziger's Avatar
I'd say a 230+ cam would be minimal in a stroker. You could undercam it to death, but why? What kind of heads do you have? Valve size? The benefits of a stroker are more torque, more cubes, more strength and more potential.
Old Jun 20, 2005 | 05:39 PM
i was wondering cause i dont want to have to buy another set of heads or cam. if i dont meet the criteria, i will scrap that idea.
Old Jun 20, 2005 | 05:51 PM
BirchMan98z's Avatar
stage II heads for 383, stage III for 396+
Big cam. Upping the cubes tends to tame cams.
Old Jun 21, 2005 | 12:50 PM
Bayer-Z28's Avatar
You'll get crazy TQ numbers out of a stroker, If built right. But, you can loose the higher tach. Benifits?? = WHEELSTANDS!!
Old Jun 21, 2005 | 01:46 PM
teke184's Avatar
well depending on your heads you should be fine...least for a reasonable amount of power. if they are stage 1s or mild 2s...don't expect 500hp.
i've known guys running 236/242 cams with .600" lift saying they are to tame in a 383.
depends on your ideas of streetable.
you could always go with a smaller stroker. i think on the LS1 if you don't bore the cylinders out you end up with something like 377. you'll have the torque of the longer stroke, little more displacement, better internals (depending on what you buy) but won't have to machine the block much.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
Boss002
Jul 9, 2015 03:33 PM
