stock heads, biggest cam?
Old Jun 23, 2004 | 05:41 AM
  #16
dist0rtion_69's Avatar
The cam you are talking about using is puny in comparison to the ones that have come out in the last year-2 years, and you will not have any vacuum problems. Its likely that you won't need to do anything but drill the throttlebody.
Peace,
Josh
Old Jun 23, 2004 | 09:41 AM
  #17
darrens99formul's Avatar
This is the cam I like and plan to get.
98-02 LS1 CC-custom4 Up to 400RWHP is obtainable with this fast ramp cam with bolt ons, STOCK heads, and dynotuning in an M6 car Lift: .581/.581 Dur@.050: 224/224 LSA: 112 114
That BTW is off of speed incs web site as one of the cams they sell. The 224/224 is a great compromise cam IMO. With a good tune it's still emmissions passable, makes good power and maintains fairly decent street manners for daily drivers.
So I say go with a 224/224 114 and mix that cam with a good tune and 3800-4000 stall torque converter. If you want to keep good street manners then get a Yank SS3800 to compliment that cam. Just don't go less then a 3500 stall or you will regret it.
Good Luck
Old Jun 23, 2004 | 02:30 PM
  #18
fdxpilot's Avatar
Originally posted by JS99Z
So will I lose a lot of low end torque with this cam? 222/224 .566 /.568 112LSA
Should I choose one with less lift? or less Duration? And I still don't know how to match the stall convertor to the cam. Now I'm frustrated. Help!
That's a relatively small cam, barely bigger than the LS6 (204/218 .551/.547 117LSA), although a 114LSA would give you better idle and emissions, if you have to pass that. You will lose a little low end torque but gain in the mid and hi end.
Old Jun 23, 2004 | 04:21 PM
  #19
FWIW: I'm running the cam in my sig.
236/239 .601/.610 111lsa
Stock heads.. all boltons sept electric water pump and fast intake.
Peace,
Josh
HectorM52
Jul 30, 2017 11:46 AM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
