Stock gear ratios
Old Sep 18, 2003 | 07:17 AM
Waroo's Avatar
Stock gear ratios
Does anyone know what the gear ratio is for a stock Camaro Z28 A4? I'm thinking about upgrading as a future mod, but was just curious as to where I'm at now.
Thanks in advance,
Navin
Old Sep 18, 2003 | 07:18 AM
teke184's Avatar
if it's the same as the lt1 cars,
if you can select 1st gear on your console with the shifter you have 3.23 (the perf ratio)
if not and you only have 2nd gear, you have 2.73's
Old Sep 18, 2003 | 08:20 AM
2001NBMZ28's Avatar
Look for the RPO code on the driver's door:
GU2 - 2.73
GU5 - 3.23
Old Sep 18, 2003 | 09:49 AM
teke184's Avatar
quote:
"I've got 2.73's and I can select 1st gear"
i guess they changed that from the lt1 cars to the ls1 cars...
sorry...
Old Sep 18, 2003 | 10:12 AM
darrens99formul's Avatar
Just look inside your drivers door like 2001nbmz28 said. Way up on top of the white sticker it will say GU2 or GU5.
If you see GU2 then when money allows swap out with a cheap set of 3.42's out of someones M6. If it says GU5 then consider keeping those gears and just adding a nice 3500 stall TC like the TCI SSF3500.
Old Sep 18, 2003 | 10:17 AM
2001NBMZ28's Avatar
If you suspect they may have been changed use the gear/mph calculator at www.f-body.org/gears/
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Jul 4, 2005 05:00 PM
