stock cam.......?.........?
hey does anyone know what the stock cam in a camaro ss m6 is??? also the lift because i might get a 220/220 in the hopes that it's not to loud but still gives me power................ which heads to.....
sorry if this question has been asked before i couldn't find it doing the search, it just said error page cannot be found.....
Re: stock cam.......?.........?
with a smaller cam like that, you don't need really high flowing heads. something like the Dart 205 heads would work great and help boost low end power. and they are well priced.
Your stock heads will work. You'd see an improvement with an LS6 intake. If you aren't going to add long tubes and get rid of the cats, you might want to consider something like the Cheatr cam. It's designed to work with stock exhaust. Notice that on the OEM cam the exhaust duration is greater than the intake and on the newer cam the exhaust lift is greater than the intake. The Cheatr cam is similarly configured.
