Steering Shaft removal for header install?
Old Nov 11, 2003 | 04:32 PM
coogsLS1's Avatar
I have been reading around and on some hooker header LT installs, the steering shaft needs to be removed? Anyone run into that problem? If so, how do you do that?
Old Nov 12, 2003 | 11:17 AM
RedDevil's Avatar
On the 2 installs I've done on those headers we took the shaft out for more clearance, they slide right in after you remove that
Old Nov 12, 2003 | 11:53 AM
coogsLS1's Avatar
how do you remove it?
Old Nov 12, 2003 | 12:33 PM
94ZRiCeKiLr's Avatar
i just loosened mine and moved it over....i have pacesetters which are basically like hookers...
Old Nov 12, 2003 | 01:18 PM
RedDevil's Avatar
We dropped the steering column inside the car, then took out the 2 bolts holding the the column in the engine bay and it slides right out
Old Nov 12, 2003 | 03:09 PM
coogsLS1's Avatar
and my last question:
When do you remove it? before or after jacking up? Before or after removing ....anything? Thanks (if my questions make any sense)
Jlo
Feb 23, 2015 12:20 PM
Airplanedoc
Feb 1, 2015 07:14 PM
Jul 4, 2005 05:00 PM
