Starting ???'s
Old Dec 27, 2009 | 04:23 PM
dickeymoore's Avatar
Starting ???'s
I have a 2001 Z28 and if the car sits for maybe 2 or more days when I go to start it in the cold morning there is a 2 or 3 second delay before the starter engages and the car starts but after that it starts fine is this normal or what and will 5W-20 motor oil work in a LS1 engine I know it calls for 5W-30 just curious?THANKS
Old Dec 27, 2009 | 04:36 PM
johnny6's Avatar
So you turn the key, hold it on the start position, and nothing happens for a few seconds then all the sudden the starter starts to turn the engine over? Or does the engine actually turn over and it takes a few seconds to start?
Old Dec 28, 2009 | 07:56 AM
AL SS590 M6's Avatar
Moderator
No on the 5-20 oil.
Old Dec 28, 2009 | 02:48 PM
Yeah I turn the key over to the start position and nothing happens till after 2 or 3 seconds then the car fires right up.THANKS
Old Dec 28, 2009 | 03:01 PM
2001NBMZ28's Avatar
First thing I'd check is the battery terminals for corrosion, if that looks good have the battery load tested. Could be something else, but start with the simple stuff.
Old Dec 28, 2009 | 04:03 PM
johnny6's Avatar
Definitely, for some reason side post battery terminals get corroded very quickly. Make sure you take them all the way out, if it's full of green/white powder then that might be your problem
Old Dec 29, 2009 | 06:48 AM
Moderator
Sticky starter soleniod. If it were corroded wires or the battery it wouldn't delay like that. It would crank slow or not start at all.
Old Dec 29, 2009 | 12:19 PM
Chrome383Z's Avatar
x2.
Old Dec 31, 2009 | 12:17 PM
So is it best to be looking to get a new starter.
Old Dec 31, 2009 | 05:28 PM
johnny6's Avatar
You could always swap starters to see if that's the problem, if not just return it to the part store and move on.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
